Re: my qt50
Joe Woods /
the symptom sounds exactly like it's on the edge of running out of gas.. you wouldn't be the first person around here to dump some fuel in the tank and find that the problem mysteriously disappears.
other than that, turn the tank's fuel valve off, pull the fuel line off the carburetor and then drain about a cup of fuel into a container. Fuel flow should be a thick, steady stream.
