Re: Fuel problem?
Joe Woods /
it does make sense that if the rear pulley is jammed and can't open all the way, lots of belt friction will be developed and, also, top speed would be restricted.
take the rear unit off the bike..(got a puller?) Remove the big nut in back of the unit.
(Unless you have the special puller) Get a big hammer and a big round piece of steel bar. Pound on that threaded part sticking out the end. Don't damage the threads.
If you're lucky, after a sharp whack or two that center piece will pop in (it's a tapered fit).
Immediately, the strong internal spring will pop the thing open..
Now you can examine the internals for damage or something... it's pretty simple.. only 5 pieces total..
The manual shows the exploded view for reassembly. Reassembly might require a couple clamps to compress the spring while putting the nut back on. I can do it with my bare hands..
Before assembly lube it with grease as the manual instructs.
  Pa50 problem, AGAIN, going fast UPHILL only...Topic by: Guillaume Bergeron Guillaume Bergeron 05/29/05 11:12AM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 11:41AM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 11:51AM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/29/05 01:01PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/29/05 01:26PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 01:54PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 01:48PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/29/05 02:06PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 02:55PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Legendre Legendre 05/29/05 02:10PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 02:24PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 02:26PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Silverfox Sullivan Silverfox Sullivan 05/30/05 12:43PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/30/05 05:33PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Silverfox Sullivan Silverfox Sullivan 05/31/05 12:09PM
  Fuel problem?Re: Anthony K Anthony K 05/31/05 10:34PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 05/31/05 10:45PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/12/05 07:55PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/12/05 11:16PM
  Re: Fuel problem?Re: Legendre Legendre 06/12/05 08:24PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/12/05 09:07PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/13/05 12:05AM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/13/05 05:47PM
  Re: Fuel problem?Re: Silverfox Sullivan Silverfox Sullivan 06/13/05 08:48PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/13/05 09:26PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/13/05 09:40PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/14/05 08:29PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/15/05 12:42AM
  Re: Fuel problem?Re: Sean Caron Sean Caron 06/14/05 08:44PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/17/05 10:41PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/18/05 01:25AM
  variator opened up pixRe: Joe Woods Joe Woods 06/18/05 01:57AM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/18/05 06:41PM
  Re: variator opened up pixRe: Joe Woods Joe Woods 06/19/05 10:37AM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/20/05 05:23PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/20/05 05:25PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/20/05 05:31PM
  Re: variator opened up pixRe: Joe Woods Joe Woods 06/21/05 02:44AM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/21/05 01:13PM
  Re: variator opened up pixRe: Joe Woods Joe Woods 06/21/05 01:24PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/21/05 01:30PM
  Re: variator opened up pixRe: Silverfox Sullivan Silverfox Sullivan 06/21/05 02:21PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/21/05 05:39PM
