Re: Fuel problem?
Joe Woods /
_i’ve removed the exhaust bolt to see if the exhaust could cause too much back presure_
You mean the big bolt in the side of the muffler? That bolt only allows you to go in and clear a small tube. If that tube is clogged, removing the bolt will do nothing... the bolt is on the outer, clogged-side of that tube. Stick a screwdriver in there and clear the tube.
All that heat means friction .. you were asking about new belts earlier too.
My guess is the belt is slipping for some reason, or that the pulleys are not operating correctly. When the front and rear variator units do not work together, but fight against eachother, lots of friction can be developed.
For instance, if the rear unit's inner face were rusted on it's shaft (not really a shaft) it would not open wide easily.. that could cause belt slipping and cause the belt to pull a lot harder than it needs to pull.
And if it wasn't mechanically able to open all the way the front pulley would be keeping the belt extremely tight at high speeds... more friction.
Mine get nice and warm but nothing like hot.. no sense that it would burn me .. Sometimes i notice it's quite cool after a ride. I think it depends on how you're riding.. steady speed or lots of speed changes.. someday i'll check it out.
  Pa50 problem, AGAIN, going fast UPHILL only...Topic by: Guillaume Bergeron Guillaume Bergeron 05/29/05 11:12AM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 11:41AM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 11:51AM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/29/05 01:01PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/29/05 01:26PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 01:54PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 01:48PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/29/05 02:06PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 02:55PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Legendre Legendre 05/29/05 02:10PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 02:24PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 02:26PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Silverfox Sullivan Silverfox Sullivan 05/30/05 12:43PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/30/05 05:33PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Silverfox Sullivan Silverfox Sullivan 05/31/05 12:09PM
  Fuel problem?Re: Anthony K Anthony K 05/31/05 10:34PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 05/31/05 10:45PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/12/05 07:55PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/12/05 11:16PM
  Re: Fuel problem?Re: Legendre Legendre 06/12/05 08:24PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/12/05 09:07PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/13/05 12:05AM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/13/05 05:47PM
  Re: Fuel problem?Re: Silverfox Sullivan Silverfox Sullivan 06/13/05 08:48PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/13/05 09:26PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/13/05 09:40PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/14/05 08:29PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/15/05 12:42AM
  Re: Fuel problem?Re: Sean Caron Sean Caron 06/14/05 08:44PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/17/05 10:41PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/18/05 01:25AM
  variator opened up pixRe: Joe Woods Joe Woods 06/18/05 01:57AM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/18/05 06:41PM
  Re: variator opened up pixRe: Joe Woods Joe Woods 06/19/05 10:37AM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/20/05 05:23PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/20/05 05:25PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/20/05 05:31PM
  Re: variator opened up pixRe: Joe Woods Joe Woods 06/21/05 02:44AM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/21/05 01:13PM
  Re: variator opened up pixRe: Joe Woods Joe Woods 06/21/05 01:24PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/21/05 01:30PM
  Re: variator opened up pixRe: Silverfox Sullivan Silverfox Sullivan 06/21/05 02:21PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/21/05 05:39PM
