Re: Fuel problem?
Legendre /
As I see it, the only reason a driven (rear) pulley would get that hot, is from belt slippage. Might also be bad bearings, but if they are making that kind of heat, the noise and roughness would be totally obvious. Or, maybe it's just a case of simple posession...
Had you considered exorcism? Light a couple pieces of charcoal in a metal or stone bowl. When they are glowing, place the bowl under the bike and thow on sage, tobacco and sweetgrass. Knickinick is good too, if you can find it. Try to blow the smoke into the exhaust, intake, gas tank and crankcase(s). Pray for intervention from friendly spirits.
Couldn't hurt at this point. If I were in your shoes, I might also consider an offering of hemp, if you know what I mean,
  Pa50 problem, AGAIN, going fast UPHILL only...Topic by: Guillaume Bergeron Guillaume Bergeron 05/29/05 11:12AM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 11:41AM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 11:51AM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/29/05 01:01PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/29/05 01:26PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 01:54PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 01:48PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/29/05 02:06PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 02:55PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Legendre Legendre 05/29/05 02:10PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 02:24PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 02:26PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Silverfox Sullivan Silverfox Sullivan 05/30/05 12:43PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/30/05 05:33PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Silverfox Sullivan Silverfox Sullivan 05/31/05 12:09PM
  Fuel problem?Re: Anthony K Anthony K 05/31/05 10:34PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 05/31/05 10:45PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/12/05 07:55PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/12/05 11:16PM
  Re: Fuel problem?Re: Legendre Legendre 06/12/05 08:24PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/12/05 09:07PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/13/05 12:05AM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/13/05 05:47PM
  Re: Fuel problem?Re: Silverfox Sullivan Silverfox Sullivan 06/13/05 08:48PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/13/05 09:26PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/13/05 09:40PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/14/05 08:29PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/15/05 12:42AM
  Re: Fuel problem?Re: Sean Caron Sean Caron 06/14/05 08:44PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/17/05 10:41PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/18/05 01:25AM
  variator opened up pixRe: Joe Woods Joe Woods 06/18/05 01:57AM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/18/05 06:41PM
  Re: variator opened up pixRe: Joe Woods Joe Woods 06/19/05 10:37AM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/20/05 05:23PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/20/05 05:25PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/20/05 05:31PM
  Re: variator opened up pixRe: Joe Woods Joe Woods 06/21/05 02:44AM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/21/05 01:13PM
  Re: variator opened up pixRe: Joe Woods Joe Woods 06/21/05 01:24PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/21/05 01:30PM
  Re: variator opened up pixRe: Silverfox Sullivan Silverfox Sullivan 06/21/05 02:21PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/21/05 05:39PM
