Re: Pa50 problem, AGAIN, going fast UPHILL only...
Legendre /
This is an odd one for sure.
It almost sounds like the variator is acting too quickly, not too slowly. From my understanding, two things control the state of the variator - RPM and load.
If the variator was acting too quickly, it would hobble the engine with too high of a gear ratio. The engine might not be able to get into the powerband. Simply not making enough horsepower to overcome the ever-increasing gear ratio.
When under load (on the uphill) the load is enough to keep the variator at a lower ratio for the same RPM - so now the engine can get further into the powerband, and make a little more speed.
Does the PA50 variator have return springs for the weights? Possible that the spring(s) are sacked? Otherwise, it seems that the engine is just not making enough power at the RPM the variator system is designed for.
  Pa50 problem, AGAIN, going fast UPHILL only...Topic by: Guillaume Bergeron Guillaume Bergeron 05/29/05 11:12AM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 11:41AM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 11:51AM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/29/05 01:01PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/29/05 01:26PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 01:54PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 01:48PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/29/05 02:06PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 02:55PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Legendre Legendre 05/29/05 02:10PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 02:24PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 02:26PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Silverfox Sullivan Silverfox Sullivan 05/30/05 12:43PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/30/05 05:33PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Silverfox Sullivan Silverfox Sullivan 05/31/05 12:09PM
  Fuel problem?Re: Anthony K Anthony K 05/31/05 10:34PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 05/31/05 10:45PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/12/05 07:55PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/12/05 11:16PM
  Re: Fuel problem?Re: Legendre Legendre 06/12/05 08:24PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/12/05 09:07PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/13/05 12:05AM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/13/05 05:47PM
  Re: Fuel problem?Re: Silverfox Sullivan Silverfox Sullivan 06/13/05 08:48PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/13/05 09:26PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/13/05 09:40PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/14/05 08:29PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/15/05 12:42AM
  Re: Fuel problem?Re: Sean Caron Sean Caron 06/14/05 08:44PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/17/05 10:41PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/18/05 01:25AM
  variator opened up pixRe: Joe Woods Joe Woods 06/18/05 01:57AM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/18/05 06:41PM
  Re: variator opened up pixRe: Joe Woods Joe Woods 06/19/05 10:37AM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/20/05 05:23PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/20/05 05:25PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/20/05 05:31PM
  Re: variator opened up pixRe: Joe Woods Joe Woods 06/21/05 02:44AM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/21/05 01:13PM
  Re: variator opened up pixRe: Joe Woods Joe Woods 06/21/05 01:24PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/21/05 01:30PM
  Re: variator opened up pixRe: Silverfox Sullivan Silverfox Sullivan 06/21/05 02:21PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/21/05 05:39PM
