Re: Pa50 problem, AGAIN, going fast UPHILL only...
Joe Woods /
ya know.. for some reason my brain tells me this could be due to a loose belt.
I know it's hard to adjust the belt. You have to pull that rear wheel back hard and tighten a few of the bolts at the same time.
Under a large load (like when it hits the hill) the belt pulls harder and there's more belt-pulley friction. Under a load, the front and rear variator units act properly.. the rear spring and front weights find the proper resistance and stress is balanced.. So the bike can go faster. That rear spring won't allow the rear pulley sides to open (raising gear ratio) unless the belt pulls hard.
If the belt is loose or slipping the variator just acts srange.
So, also check for a slipping belt.. a bit of grease or oil on the pulleys or the belt can do it.
  Pa50 problem, AGAIN, going fast UPHILL only...Topic by: Guillaume Bergeron Guillaume Bergeron 05/29/05 11:12AM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 11:41AM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 11:51AM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/29/05 01:01PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/29/05 01:26PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 01:54PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 01:48PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/29/05 02:06PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 02:55PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Legendre Legendre 05/29/05 02:10PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 02:24PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Joe Woods Joe Woods 05/29/05 02:26PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Silverfox Sullivan Silverfox Sullivan 05/30/05 12:43PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Guillaume Bergeron Guillaume Bergeron 05/30/05 05:33PM
  Re: Pa50 problem, AGAIN, going fast UPHILL only...Re: Silverfox Sullivan Silverfox Sullivan 05/31/05 12:09PM
  Fuel problem?Re: Anthony K Anthony K 05/31/05 10:34PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 05/31/05 10:45PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/12/05 07:55PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/12/05 11:16PM
  Re: Fuel problem?Re: Legendre Legendre 06/12/05 08:24PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/12/05 09:07PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/13/05 12:05AM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/13/05 05:47PM
  Re: Fuel problem?Re: Silverfox Sullivan Silverfox Sullivan 06/13/05 08:48PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/13/05 09:26PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/13/05 09:40PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/14/05 08:29PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/15/05 12:42AM
  Re: Fuel problem?Re: Sean Caron Sean Caron 06/14/05 08:44PM
  Re: Fuel problem?Re: Guillaume Bergeron Guillaume Bergeron 06/17/05 10:41PM
  Re: Fuel problem?Re: Joe Woods Joe Woods 06/18/05 01:25AM
  variator opened up pixRe: Joe Woods Joe Woods 06/18/05 01:57AM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/18/05 06:41PM
  Re: variator opened up pixRe: Joe Woods Joe Woods 06/19/05 10:37AM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/20/05 05:23PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/20/05 05:25PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/20/05 05:31PM
  Re: variator opened up pixRe: Joe Woods Joe Woods 06/21/05 02:44AM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/21/05 01:13PM
  Re: variator opened up pixRe: Joe Woods Joe Woods 06/21/05 01:24PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/21/05 01:30PM
  Re: variator opened up pixRe: Silverfox Sullivan Silverfox Sullivan 06/21/05 02:21PM
  Re: variator opened up pixRe: Guillaume Bergeron Guillaume Bergeron 06/21/05 05:39PM
