Re: Ciao/Bravo problem - dying
Joe Woods /
When electrical components like the condenser or coil fail, the bike will then run like crap all the time or it may not run at all.
But if a bike starts, idles and runs perfectly fine for any extended length of time but suddenly just cuts out once in a while, first suspect some kinda wiring problem .. a bad kill switch connection or loose wiring or similar. If it started to happen recently, re-inspect everything near any work you did on the bike lately..
If the bike runs good but has an intermittant problem, the basic systems like carburation and ignition and their components are ok.. look elsewhere.
