Vespa ciao won't work
Thomas Rozeske /
Hi, i have a Vespa ciao that has worked for my entire life with no problems ever. It just recently stopped working, what happened is when i started the moped, it ran fine but wouldn't get above 10 mph so i stopped it and it never ran again. It has compression and i just replaced the spark plug. If you know what is wrong or have an idea please send me something.
Re: Vespa ciao won't work
Bruce Wilkinson /
Use Freds guide in the articles and check to see if you have spark. If you do then I would take the carb off and give it a really good cleaning. bruce
How many miles does it have on the engine? Could be a clogged muffler. Try removing it and see if it will start and run faster. Will be a bit noisy so warn the neighbors.
Could also be a blown base gasket.
Also as Bruce suggested use Fred's giude and go through the trouble shooting step by step and assume nothing!
