sure could.. or for some other reason the fuel level in the float bowl is too high.
Remove the float bowl.. is there a long thin vertical tube sticking up inside? That would be the overflow tube.
And if fuel level goes above the top of that tube, fuel will drain out of the drain-screw hole at the bottom of the bowl.
