Re: mobylette choke
Joe Woods /
it does sound like not enough fuel (compared to the amount of air) is getting through the carburetor and into the engine.
The closed choke restricts air intake and "corrects" the mixture.
So, if fuel is now getting into the float bowl, the thing to check for is a clean float bowl and that the main jet's hole is open and clear. A tiny bit of floating crap will get sucked up and partially clog that jet..
Lean = lots of air compared to fuel..
Rich = less air or more fuel in the mix.. same difference..
Fuel mixture:
A 1:10 (fuel:air) means 1 pound of fuel to 10 pounds of air. (it's measured by weight .. a lot of air weigh quite a bit..)
A 1:3 mixture is much richer than above.. (only 3 pounds of air instead of 10 pounds of air is mixed with that same 1 pound of fuel.)
1:14 ... this is leaner than both the others.. a larger amount of air (14 pounds) is being mixed with that same 1 pound of fuel
When starting the engine needs a very rich mix, like 1:2 or 1:3.
Idling requires less fuel and more air (leaner) like 1:8 or so. Normal running is leaner still.. somewhere around 1:13.
  mobylette chokeTopic by: moped_bandit moped_bandit 05/27/05 06:00PM
  Re: mobylette chokeRe: Joe Woods Joe Woods 05/27/05 06:15PM
  Re: mobylette chokeRe: Mike Scouty McScoutington Mike Scouty McScoutington 05/27/05 07:46PM
  Re: mobylette chokeRe: moped_bandit moped_bandit 05/27/05 08:03PM
  Re: mobylette chokeRe: Joe Woods Joe Woods 05/27/05 08:16PM
  Re: mobylette chokeRe: moped_bandit moped_bandit 05/27/05 08:22PM
  Re: mobylette chokeRe: Joe Woods Joe Woods 05/27/05 08:40PM
  Re: mobylette chokeRe: moped_bandit moped_bandit 05/27/05 08:46PM
  Re: mobylette chokeRe: See Ya Moped Army See Ya Moped Army 05/27/05 11:13PM
  Re: mobylette chokeRe: moped_bandit moped_bandit 05/28/05 05:28PM
  Re: mobylette chokeRe: moped_bandit moped_bandit 05/28/05 08:59PM
  Re: mobylette chokeRe: Joe Woods Joe Woods 05/28/05 09:06PM
  Re: mobylette chokeRe: moped_bandit moped_bandit 05/28/05 09:10PM
  Re: mobylette chokeRe: Joe Woods Joe Woods 05/28/05 09:21PM
  Re: mobylette chokeRe: moped_bandit moped_bandit 05/28/05 09:28PM
  Re: mobylette chokeRe: Legendre Legendre 05/28/05 09:13PM
  Re: mobylette chokeRe: moped_bandit moped_bandit 05/28/05 09:19PM
  Re: mobylette chokeRe: moped_bandit moped_bandit 05/29/05 06:45PM
  Re: mobylette chokeRe: Legendre Legendre 05/29/05 08:15PM
  Re: mobylette chokeRe: moped_bandit moped_bandit 05/29/05 08:23PM
  Re: mobylette chokeRe: toonces toonces 05/30/05 12:22AM
  Re: mobylette chokeRe: moped_bandit moped_bandit 05/30/05 07:13AM
  Re: mobylette chokeRe: Legendre Legendre 05/30/05 11:16AM
  Re: mobylette chokeRe: moped_bandit moped_bandit 05/30/05 04:55PM
