still got puch probs
Ok, I went thru and cleaned the carb replace fuel line and put in a new fuel filter and replaced the spark plug. Still wont run. Checked for spark... there is none. So I have an ignition problem what steps should I take to track down the problem? Thanks
Re: still got puch probs
use the old thread so we can figure out more details!
Jason Luther /
did you try a _new_ spark plug? your most likely culprit is a bad ground somewhere. are your kill and light switches and eveything all hooked up? any wires hanging loose somewhere?
yes replaced plug, my kill switch and light switch are both broken, but they are both stuck in the "on position" I just got the ped a few weeks ago and hadn't got around to replacing them im going to go over the electrical stuff tomorrow
Jason Luther /
i bet thats your problem. there are wiring diagrams at mopedriders.org . you could always hot wire it by connecting the black wire from the engine to the blue wire for the coil directly (with no other wires)
