Re: two questions
mopednorth /
I'll check my local autoparts store for the gasket stuff (thanks for the tip for the head gasket!) and pray for darker stuff. And as far as the leak, I hope the tape helps (is it the same stuff plumbers use-because I have some that kicking around) if not is it possible that the little ball-bearing is the problem? And Don-you are the king!!! THanks for the help.
