Re: Vespa Ciao problems--adjusting points
Bill W /
A couple of things
If you are getting spark, remove the spark plug and spray some starter fluid in the spark plug hole in the head and reinstall the plug and cap and try to see if it will try to start. If it does, you still have a clogged main jet in your carb.
If it is not a fuel problem you may need to replace the the points and condensor.
