Re: Vespa Ciao problems--adjusting points
Bruce Wilkinson /
If you have a volt/ohm meter you can test the bulbs to see if the filament is broken. The further you turn the idle screw in ,the more it opens the slide and the faster the engine will rev.If you can get it started, you can slow it down after the engine warms up.I'm not sure I understand what the symtems are??bruce
