Re: Vespa Ciao problems--adjusting points
Yep, the throttle slide is in the carb correctly. At least I think it is. the slide is adjusted so that there is a little tiny gap at the bottom of the carb jet (if you're looking at it from the side) when the throttle is at rest. Is this normal? Should there be no gap at all when the throttle is at rest?
Brennen
