Targa LX not shifting to second
Well I thought it was the clutch shoes being worn out and may still be but they didnt look bad or anything, Is there anyway to get the second gear clutch out from that casing or is it always supposed to be stuck in there. Also I got that from nut off there with using a socket wrench and by putting a wrench (like you would use for taking off a oil filter off) around that outer casing but the other problem is that the casing free spins they way i will have to turn it to tighten the nut back up, is there a method i can use to tighten that back up with out the special tool or will i need that too. thanks. I can take pictures of what i am talking about if need be. Just let me know.
Thanks!
Justin
