Re: AMF Electrical
neil74 /
There are only two wires to each switch. The motor has a compression release lever hooked up to the throttle, appears to engage when in run position. How do you start it, Do you pedal the bike to speed and flip the rear lever to engage motor and go? Or do you somehow push the pedals while it is on the kickstand?
