Re: AMF Electrical
Legendre /
neil,
If it has an 1154 taillamp, then that is a 6V system.
This isn't 100% accurate, but if you have three wires on each of the brake light switches (on the hand levers) then it's the type of system that needs a good taillamp to make spark.
There are two basic manual starting systems; one relies on a compression release and centrifigal clutch, the other just on a manually operated clutch.
