Re: 1977 Garelli NO1
Joe Woods /
i dunno what you meant by:
_i mounted the exhaust one hole closer because the other one was missing the rubber_
Something to do with exhaust could be part of it since greater backpressure gets things like the piston crown hotter.
This added heat promotes a faster burning mixture. If ignition timing is already borderline-too-advanced, some added heat in the combustion chamber could push it over the edge of pre-ignition.
