1977 Garelli NO1
David Rencher /
ok so i cant figure this one out, my Garelli runs great when i first start it and ride for a little while but after it has been running for about 15 min or so and i go up a big hill or have it wide open for a few min it sounds like the piston starts "tinging" i recently switched to synthetic 2 cycle oil and that helps some.
the only thing i can think that is causing this is when it is running hard it is not getting enough gas or the gas cap is preventing enough suction, also i have had this ped for over a year and a half and the problem just started about a month ago. and yes i have cleaned everything and checked for good gas flow the works and my rings look fine and there is no scuffing in my cylinder.
but i wanted to see if anyone else had any ideas about what would cause this or has anyone else had this problem with a Garelli.
