Re: Puch won't run -- HELP!
Ja'Far Rogers /
by bearings he means 'crank' breakings, they transfer power from the piston to the transmission.
IF and when you get the engine running you should listen for a harsh screeching sound as you gun the throttle, if you can hear that sound then replace your crank bearings. i had the same problem about a month ago and lost power
