moby spark timing
Kevin Ibbetson /
I don't have one of those timing devices that screw into the spark plug hole but I do have a degree wheel. Anybody know when the points should open on a '70 40V Mobylette? Just slightly before TDC i'm guessing but how many degrees. Thanks
Re: moby spark timing
it's usually around 12, maybe 15 deg BTDC on most bikes .. THIS break> Mobylette manual says anywhere from 1.5 to 3 mm BTDC for the various models.. Check and see if your bike is listed on the specs page. (page 5)
A little depth gauge is not hard to whip up.. thread a hole in a flat piece of steel or aluminum and secure the thing in position over the spark plug hole.. then screw a bolt or threaded rod down through it until the bolt touches the piston at TDC..
Threads per inch of the bolt can be easily converted to vertical distance. A 1/4" x 20 threaded rod is gonna drop .05 " per revolution. 0.05" = 1.27mm .. So, 2 turns of the bolt is near 2.5mm. (if you use metric stuff, it wont even require conversion)
Kevin Ibbetson /
thanks guys, great info, i'm going to file it.
