Re: Puch running hot and have to adjust the idle o
Bill W /
2 things
If it is a 2 speed, the transmission may have too much transmission fluid in it. It is easy to ovefill 2 speed Puch trannys because the fill plug is on top of the tranny.
You can drain it (drain hex head nut under the rear of the engine (tranny). Refill it with 9.5 ounces of ATF type "F".
Second thing, the idle issue. sounds like you have a vaccum leak around the engine to intake manifold connection or the carb to intake manifold connection. It's sucking in extra air making you run lean and Hot. Make sure all the screws and bolts associated with the carb are tight (but don't overtighten).
  Puch running hot and have to adjust the idle oftenTopic by: Bill Bill 05/22/05 05:42PM
  Re: Puch running hot and have to adjust the idle oRe: Joe Woods Joe Woods 05/22/05 05:53PM
  Re: Puch running hot and have to adjust the idle oRe: Bill Bill 05/22/05 06:06PM
  Re: Puch running hot and have to adjust the idle oRe: Joe Woods Joe Woods 05/22/05 06:13PM
  Re: Puch running hot and have to adjust the idle oRe: Louie Armstrong Louie Armstrong 05/22/05 08:08PM
  Re: Puch running hot and have to adjust the idle oRe: Ja'Far Rogers Ja'Far Rogers 05/22/05 08:16PM
  Re: Puch running hot and have to adjust the idle oRe: Bill Bill 05/22/05 08:27PM
  Re: Puch running hot and have to adjust the idle oRe: Bill Bill 05/22/05 08:28PM
  Re: Puch running hot and have to adjust the idle oRe: Smitty Smith Smitty Smith 05/23/05 08:11AM
  Re: Puch running hot and have to adjust the idle oRe: toonces toonces 05/22/05 08:59PM
  Re: Puch running hot and have to adjust the idle oRe: Ja'Far Rogers Ja'Far Rogers 05/22/05 11:19PM
  Re: Puch running hot and have to adjust the idle oRe: Ray West Ray West 05/22/05 11:32PM
  Re: Puch running hot and have to adjust the idle oRe: Ray West Ray West 05/22/05 11:45PM
  Re: Puch running hot and have to adjust the idle oRe: Ja'Far Rogers Ja'Far Rogers 05/23/05 04:12PM
  Re: Puch running hot and have to adjust the idle oRe: Bill W Bill W 05/24/05 12:54AM
  Re: Puch running hot and have to adjust the idle oRe: Bill Bill 05/24/05 09:34PM
