Re: Puch running hot and have to adjust the idle o
Smitty Smith /
Most Maxi's were powered by the one-speed E50 engine, while the Magnum, and some Newports, and an occasional Cobra and certain Maxi's had the two-speed za50.
From my experiences and readings, the E50 is about as close to bullet-proof as you can get from a moped engine. There are very sluggish off the line, but run great after 10-15mph, on flat ground...but again leave much to be desired as for climbing hills. It has one centrifugal clutch, usually two-shoe (after-market and later years had three-shoes). The clutch shoes are adjustable, by turning in or out the set screw above the spring in each shoe.
The "2" classification on your Maxi, more than likely refers to the 2hp engine, which should have a 14mm carb and intake, and depending on which piston/cylinder, will have a 12-14mm round intake port, or a rectangle shaped intake port.
Hope this helps.
Smitty
  Puch running hot and have to adjust the idle oftenTopic by: Bill Bill 05/22/05 05:42PM
  Re: Puch running hot and have to adjust the idle oRe: Joe Woods Joe Woods 05/22/05 05:53PM
  Re: Puch running hot and have to adjust the idle oRe: Bill Bill 05/22/05 06:06PM
  Re: Puch running hot and have to adjust the idle oRe: Joe Woods Joe Woods 05/22/05 06:13PM
  Re: Puch running hot and have to adjust the idle oRe: Louie Armstrong Louie Armstrong 05/22/05 08:08PM
  Re: Puch running hot and have to adjust the idle oRe: Ja'Far Rogers Ja'Far Rogers 05/22/05 08:16PM
  Re: Puch running hot and have to adjust the idle oRe: Bill Bill 05/22/05 08:27PM
  Re: Puch running hot and have to adjust the idle oRe: Bill Bill 05/22/05 08:28PM
  Re: Puch running hot and have to adjust the idle oRe: Smitty Smith Smitty Smith 05/23/05 08:11AM
  Re: Puch running hot and have to adjust the idle oRe: toonces toonces 05/22/05 08:59PM
  Re: Puch running hot and have to adjust the idle oRe: Ja'Far Rogers Ja'Far Rogers 05/22/05 11:19PM
  Re: Puch running hot and have to adjust the idle oRe: Ray West Ray West 05/22/05 11:32PM
  Re: Puch running hot and have to adjust the idle oRe: Ray West Ray West 05/22/05 11:45PM
  Re: Puch running hot and have to adjust the idle oRe: Ja'Far Rogers Ja'Far Rogers 05/23/05 04:12PM
  Re: Puch running hot and have to adjust the idle oRe: Bill W Bill W 05/24/05 12:54AM
  Re: Puch running hot and have to adjust the idle oRe: Bill Bill 05/24/05 09:34PM
