Re: Puch running hot and have to adjust the idle o
Joe Woods /
Two speeds often have trouble on hills.. they just dont shift when they should.. depends on the hill's slope, vehicle weight, gear ratio, etc. Not a lot can be done to make it climb steep hills better other than sprocket (final gear ratio) changes. Different clutch springs can alter where a bike shifts but that's kinda difficult to do.
Idle should be set only when the engine is good and hot. If it's adjusted on a cold engine it'll only idle when the engine is cold.
Aside from that, a clean carb.. correct float level, etc matter. And look for vacuum leaks around the intake manifold. (Spray some Starter Fluid around the area.. if the engine responds, there's a leak)
  Puch running hot and have to adjust the idle oftenTopic by: Bill Bill 05/22/05 05:42PM
  Re: Puch running hot and have to adjust the idle oRe: Joe Woods Joe Woods 05/22/05 05:53PM
  Re: Puch running hot and have to adjust the idle oRe: Bill Bill 05/22/05 06:06PM
  Re: Puch running hot and have to adjust the idle oRe: Joe Woods Joe Woods 05/22/05 06:13PM
  Re: Puch running hot and have to adjust the idle oRe: Louie Armstrong Louie Armstrong 05/22/05 08:08PM
  Re: Puch running hot and have to adjust the idle oRe: Ja'Far Rogers Ja'Far Rogers 05/22/05 08:16PM
  Re: Puch running hot and have to adjust the idle oRe: Bill Bill 05/22/05 08:27PM
  Re: Puch running hot and have to adjust the idle oRe: Bill Bill 05/22/05 08:28PM
  Re: Puch running hot and have to adjust the idle oRe: Smitty Smith Smitty Smith 05/23/05 08:11AM
  Re: Puch running hot and have to adjust the idle oRe: toonces toonces 05/22/05 08:59PM
  Re: Puch running hot and have to adjust the idle oRe: Ja'Far Rogers Ja'Far Rogers 05/22/05 11:19PM
  Re: Puch running hot and have to adjust the idle oRe: Ray West Ray West 05/22/05 11:32PM
  Re: Puch running hot and have to adjust the idle oRe: Ray West Ray West 05/22/05 11:45PM
  Re: Puch running hot and have to adjust the idle oRe: Ja'Far Rogers Ja'Far Rogers 05/23/05 04:12PM
  Re: Puch running hot and have to adjust the idle oRe: Bill W Bill W 05/24/05 12:54AM
  Re: Puch running hot and have to adjust the idle oRe: Bill Bill 05/24/05 09:34PM
