Re: Hobbit won't rev
Cory Mohr /
Ok I have worked and owned on hobbits before. I also had the same problems that you were having. Ok first you should clean your exhaust or get a new one. Then just remove the air filter and the plastic tube holding it in. This will not hurt the engine b/c they have a huge jet in the carb. Make sure the brakes are not dragging and the tires are pumped up. A new sparkplug will also help a little. Make sure your drive belt is tightened. If you do this I am positive your hobbit will gain speed.
  Hobbit won't revTopic by: Larry Ward Larry Ward 05/21/05 09:46PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/21/05 11:10PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/22/05 08:16AM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/22/05 08:41AM
  Re: Hobbit won't revRe: Saabsonettguy . Saabsonettguy . 05/22/05 11:42AM
  Re: Hobbit won't revRe: Frank Garland Frank Garland 05/22/05 12:38PM
  Re: Hobbit won't revRe: Silverfox Sullivan Silverfox Sullivan 05/22/05 02:55PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/22/05 08:44PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/22/05 11:29PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/22/05 11:43PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/22/05 11:54PM
  Re: Hobbit won't revRe: Silverfox Sullivan Silverfox Sullivan 05/23/05 01:34PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/23/05 03:26PM
  Re: Hobbit won't revRe: Don Ohio Don Ohio 05/24/05 09:50PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/25/05 08:59PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/28/05 02:40PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/28/05 05:53PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/28/05 07:08PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/28/05 07:20PM
  Re: Hobbit won't revRe: Cory Mohr Cory Mohr 05/28/05 10:22PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 06/01/05 07:58AM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 06/01/05 08:42AM
