Re: Hobbit won't rev
Silverfox Sullivan /
If you have to get back into the carb the "emulsion tube" is in the main fuel passage. It is held in by the main jet. After removing the main jet knock the body straight down against a block of wood. The tube should drop out.
Clean everything well. Make sure that the main jet is clear.
I use a set of welding tip cleaners. Starting with the smallest and working up until the next larger size will not fit. Go easy but make sure that it is clean.
  Hobbit won't revTopic by: Larry Ward Larry Ward 05/21/05 09:46PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/21/05 11:10PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/22/05 08:16AM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/22/05 08:41AM
  Re: Hobbit won't revRe: Saabsonettguy . Saabsonettguy . 05/22/05 11:42AM
  Re: Hobbit won't revRe: Frank Garland Frank Garland 05/22/05 12:38PM
  Re: Hobbit won't revRe: Silverfox Sullivan Silverfox Sullivan 05/22/05 02:55PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/22/05 08:44PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/22/05 11:29PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/22/05 11:43PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/22/05 11:54PM
  Re: Hobbit won't revRe: Silverfox Sullivan Silverfox Sullivan 05/23/05 01:34PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/23/05 03:26PM
  Re: Hobbit won't revRe: Don Ohio Don Ohio 05/24/05 09:50PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/25/05 08:59PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/28/05 02:40PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/28/05 05:53PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/28/05 07:08PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/28/05 07:20PM
  Re: Hobbit won't revRe: Cory Mohr Cory Mohr 05/28/05 10:22PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 06/01/05 07:58AM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 06/01/05 08:42AM
