Re: Hobbit won't rev
Joe Woods /
Someone else asked about emulsion tube removal today .. thread is called "pa50 carb questions"
"THREAD":https://www.mopedarmy.com/forums/discuss/6/20793/20780/
I know you already answered that the choke is open.. but this sounds almost identical to a closed choke. The bike runs like crap up about 8 or 10 MPH or so.. If you disassembled the carb, check it for correct assembly. And as someone else noted (frankman) that float bowl can be installed backwards and will then cause all sorts of problems.
The drain screw on the bowl should be on the right side of the bike. This screw can be accessed through a special hole in the pedal sprocket and then through a hole in the swingarm when they are lined up..
While messing with the muffler, you might think about removing it so you can check the exhaust port for carbon build-up..
  Hobbit won't revTopic by: Larry Ward Larry Ward 05/21/05 09:46PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/21/05 11:10PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/22/05 08:16AM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/22/05 08:41AM
  Re: Hobbit won't revRe: Saabsonettguy . Saabsonettguy . 05/22/05 11:42AM
  Re: Hobbit won't revRe: Frank Garland Frank Garland 05/22/05 12:38PM
  Re: Hobbit won't revRe: Silverfox Sullivan Silverfox Sullivan 05/22/05 02:55PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/22/05 08:44PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/22/05 11:29PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/22/05 11:43PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/22/05 11:54PM
  Re: Hobbit won't revRe: Silverfox Sullivan Silverfox Sullivan 05/23/05 01:34PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/23/05 03:26PM
  Re: Hobbit won't revRe: Don Ohio Don Ohio 05/24/05 09:50PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/25/05 08:59PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/28/05 02:40PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/28/05 05:53PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/28/05 07:08PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/28/05 07:20PM
  Re: Hobbit won't revRe: Cory Mohr Cory Mohr 05/28/05 10:22PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 06/01/05 07:58AM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 06/01/05 08:42AM
