Re: Hobbit won't rev
Silverfox Sullivan /
Check for adequate fuel flow.
Shut off fuel tap, pull right hand chain cover, with a long skinney screwdriver reach thru the web of the chain sprocket and remove the float bowl drain plug, turn fuel tap on, see if you get a decent flow. If not, shut off tap, pull hose from tap, turn tap on. If no flow, screen in tap is plugged up. Pull tap and clean out.
If fuel flow is OK then I would agree with joew that it is probably a problem in the carb. When you had the carb apart did you remove the emulsion tube and the main jet?
Is the engine revving? Remove left side variator cover and see if it is working.
  Hobbit won't revTopic by: Larry Ward Larry Ward 05/21/05 09:46PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/21/05 11:10PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/22/05 08:16AM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/22/05 08:41AM
  Re: Hobbit won't revRe: Saabsonettguy . Saabsonettguy . 05/22/05 11:42AM
  Re: Hobbit won't revRe: Frank Garland Frank Garland 05/22/05 12:38PM
  Re: Hobbit won't revRe: Silverfox Sullivan Silverfox Sullivan 05/22/05 02:55PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/22/05 08:44PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/22/05 11:29PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/22/05 11:43PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/22/05 11:54PM
  Re: Hobbit won't revRe: Silverfox Sullivan Silverfox Sullivan 05/23/05 01:34PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/23/05 03:26PM
  Re: Hobbit won't revRe: Don Ohio Don Ohio 05/24/05 09:50PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/25/05 08:59PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/28/05 02:40PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/28/05 05:53PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/28/05 07:08PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/28/05 07:20PM
  Re: Hobbit won't revRe: Cory Mohr Cory Mohr 05/28/05 10:22PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 06/01/05 07:58AM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 06/01/05 08:42AM
