Re: Hobbit won't rev
Joe Woods /
If it never ran right and there are no other clues, yeah .. check the exhaust .. That big bolt in the right side of the muffler (behind the heat shield) gives access to a tiny baffle tube.. the tube is the first thing to get packed with carbon. All exhaust must pass through that tube. Poke a screwdriver in there.
check everything related to air intake. The bikes are sensitive to too much or too little air intake.
Since the carb was plugged up, surely cleaning the carb made some difference? If not, it's likely there's something else going on unrelated to carburation.. (be SURE its clean.. i have screwed up a carb-cleaning job more than once)
ignition seems ok since it starts and idles, but ignition misfires can be mistaken for fuel mixture troubles.
Check compression.. torque the head bolts ..
I really think it's carburation but it could be many other things.. there's no easy way to diagnose from a distance.. gotta get down and check everything until you find something.
  Hobbit won't revTopic by: Larry Ward Larry Ward 05/21/05 09:46PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/21/05 11:10PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/22/05 08:16AM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/22/05 08:41AM
  Re: Hobbit won't revRe: Saabsonettguy . Saabsonettguy . 05/22/05 11:42AM
  Re: Hobbit won't revRe: Frank Garland Frank Garland 05/22/05 12:38PM
  Re: Hobbit won't revRe: Silverfox Sullivan Silverfox Sullivan 05/22/05 02:55PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/22/05 08:44PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/22/05 11:29PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/22/05 11:43PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/22/05 11:54PM
  Re: Hobbit won't revRe: Silverfox Sullivan Silverfox Sullivan 05/23/05 01:34PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/23/05 03:26PM
  Re: Hobbit won't revRe: Don Ohio Don Ohio 05/24/05 09:50PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/25/05 08:59PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/28/05 02:40PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/28/05 05:53PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 05/28/05 07:08PM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 05/28/05 07:20PM
  Re: Hobbit won't revRe: Cory Mohr Cory Mohr 05/28/05 10:22PM
  Re: Hobbit won't revRe: Larry Ward Larry Ward 06/01/05 07:58AM
  Re: Hobbit won't revRe: Joe Woods Joe Woods 06/01/05 08:42AM
