Peugeot carb parts
Anybody know where I can find the plastic top for a peugeot 103 carb?
Is there a good alternative dellorto carb for these bikes?
Re: Peugeot carb parts
Dellortos are very tall, I think I might I might have enough room to fit a 19mm Dellorto PHGB on my TSE. Also, I have a super rare Gurtner carb that has the cables on the side, not on top. I have no idea of the clearance of a normal 103, but i know that most other mopeds require fabrication to the intake manifolds so they come out through the side. Heres a pic of my carb. Dellortos are the best choice because the jets can be bought anywhere.
woops...
So what do you suggest I do for getting a new carb for it?
My current one is leaking air, and I assume it's through the top from the plastic piece. So I either need that peice or to find a new carb.
try sealing the leak off???? use epoxy or something simular. Trial and error man, use many things till one works.
Well I'm not going to seal the plastic piece to the top of the carb. I think the plastic is worn around the edges of the top of the carb.
Who uses plastic as a top for a carb??!
