Re: Puch: High Idle, Sluggish at start.
Daniel Van Donsel /
sounds like you are overjetted.... my Newport does the same thing with anything larger than a 60 jet..(with the plug out on the back of the airbox or a Hi Perf a/f) or a 58 jet with the plug in and that's with a Biturbo... the stock jet is a 50 with a Stock pipe and the plug in the airbox..
When I was running a stock pipe.... I had a 60 jet in it and it did the exact same thing you describe... try a 54...52... or a 50 and I bet it will take off just fine when you twist the throttle open!
It also makes a difference what size manifold you are using... I got better low end with a smaller (12/14mm) intake than with a 15mm and the 15mm carb really dumps a lot of gas in the piston... it may run better with a 12 or 14 with the stock pipe!
  Puch: High Idle, Sluggish at start.Topic by: Derf Yenrab Derf Yenrab 05/18/05 09:23AM
  Re: Puch: High Idle, Sluggish at start.Re: Daniel Van Donsel Daniel Van Donsel 05/18/05 11:06AM
  Re: Puch: High Idle, Sluggish at start.Re: Brett Walker Brett Walker 05/18/05 11:27AM
  Re: Puch: High Idle, Sluggish at start.Re: Steamboat Aka J. R. Stevens Steamboat Aka J. R. Stevens 05/18/05 11:45AM
  Re: Puch: High Idle, Sluggish at start.Re: Daniel Van Donsel Daniel Van Donsel 05/18/05 12:31PM
  Re: Puch: High Idle, Sluggish at start.Re: Brett Walker Brett Walker 05/18/05 01:06PM
  Re: Puch: High Idle, Sluggish at start.Re: Daniel Van Donsel Daniel Van Donsel 05/18/05 01:14PM
  Re: Puch: High Idle, Sluggish at start.Re: Brett Walker Brett Walker 05/18/05 01:46PM
  Re: Puch: High Idle, Sluggish at start.Re: Daniel Van Donsel Daniel Van Donsel 05/18/05 02:33PM
  Re: Puch: High Idle, Sluggish at start.Re: Joe Woods Joe Woods 05/18/05 02:58PM
  Re: Puch: High Idle, Sluggish at start.Re: Brett Walker Brett Walker 05/18/05 03:27PM
  Re: Puch: High Idle, Sluggish at start.Re: Steamboat Aka J. R. Stevens Steamboat Aka J. R. Stevens 05/18/05 04:07PM
  Re: Puch: High Idle, Sluggish at start.Re: Daniel Van Donsel Daniel Van Donsel 05/18/05 04:33PM
  Re: Puch: High Idle, Sluggish at start.Re: Brett Walker Brett Walker 05/18/05 04:41PM
  Re: Puch: High Idle, Sluggish at start.Re: Derf Yenrab Derf Yenrab 05/19/05 06:08PM
  Re: Puch: High Idle, Sluggish at start.Re: Jason Luther Jason Luther 05/19/05 07:39PM
  Re: Puch: High Idle, Sluggish at start.Re: Daniel Van Donsel Daniel Van Donsel 05/19/05 10:40PM
  Re: Puch: High Idle, Sluggish at start.Re: Derf Yenrab Derf Yenrab 05/19/05 10:46PM
  Re: Puch: High Idle, Sluggish at start.Re: Daniel Van Donsel Daniel Van Donsel 05/19/05 10:54PM
  Re: Puch: High Idle, Sluggish at start.Re: Derf Yenrab Derf Yenrab 05/20/05 06:19AM
  Re: Puch: High Idle, Sluggish at start.Re: Daniel Van Donsel Daniel Van Donsel 05/20/05 08:07AM
  Re: Puch: High Idle, Sluggish at start.Re: Derf Yenrab Derf Yenrab 05/20/05 11:36AM
  Re: Puch: High Idle, Sluggish at start.Re: Daniel Van Donsel Daniel Van Donsel 05/20/05 01:56PM
  Re: Puch: High Idle, Sluggish at start.Re: Derf Yenrab Derf Yenrab 05/20/05 06:08PM
  Re: Puch: High Idle, Sluggish at start.Re: Brett Walker Brett Walker 05/21/05 01:40AM
  Re: Puch: High Idle, Sluggish at start.Re: Daniel Van Donsel Daniel Van Donsel 05/21/05 01:48AM
  Re: Puch: High Idle, Sluggish at start.Re: Brett Walker Brett Walker 05/21/05 02:20AM
  Re: Puch: High Idle, Sluggish at start.Re: Derf Yenrab Derf Yenrab 05/21/05 04:57AM
