moby petcock
ok my moby petcock is leaking,.
are petcocks specific or can i buy just any for this bike.?
Re: moby petcock
as long as it fits. i had a petcock from a different bike on my cobra.
Re: moby petcock
cool i will throw one on tomorrow then, thanx
Re: moby petcock
sure thing.
Re: moby petcock
If you don't have one that fits, Chris at Mopedwarehouse.com sells a decent one for $19.95 + ship.
It might screw in too far, and interfere with the frame. If this is the case, he says that you can use a washer under the metal seal cup to shim it back, so it won't interfere.
Re: moby petcock
ooh good to know ill look there if i cant get this one to work.
i may also just get it anyway, just incase
thanx
Re: moby petcock
just go to napa and get a lawn mower fuel shutoff valve for $5
it threads in just perfectly, and has a screen filter thing to keep rust out,
no reserve tank.
It works great, but the side panel needs to be slightly modified to access it.
Re: moby petcock
oh rock thanx i like that idea better than spending $20
thanx for the help
Re: moby petcock
i put in the mower shut off vavle and it works great
thanx again dan adams
Re: moby petcock
should i put some kind of sealer on the thread though???
i have it on and it seemsfine but i am being paranoid.
Re: moby petcock
yes you may be paranoid, but there is stuff called blue lock tight. it is a good idea to put it on all sorts of stuff that can wiggle loose. it is a blue liquid that you dribble onto bolts before adding nuts.
I never have used it on petcocks
Re: moby petcock
ive used it for other aplications but wasnt too sure if it would be all that great for the petcock. i was thinking it may get dissolved, maybe ill try it.
Re: moby petcock
Try a few wraps of teflon tape on any fluid-tight threaded connection.
Re: moby petcock
i have some of that ill give it a shot
all teflon tape is the same correct?
Re: moby petcock
plumbers tape.. teflon tape.. maybe 99 cents a roll unless its on sale.. thin white stuff on a roll.
Re: moby petcock
oh i know i have some i wasnt sure if there were different thicknesses i should use
