removing carb from a3
Nathan Edwards /
Is it easiest to remove he intake manifold and then pull that out with the carb? I cant seem to just get at the carb to pull it out. Im too used to my Grande... If this isnt right, what is the best way to go about pulling the carb?
Thanks all...
Nate
Re: removing carb from a3
Don Pflueger /
the best way is to remove the two top engine mounting bolts, then loosen the bottom one and let the engine pivot down.
