Re: Motobecane Cady - kinda slow
Legendre /
IIRC, motobecane calls for 25:1 for break-in, and 32:1 for general use. With a modern synthetic oil, you should be fine running 40:1, or even a little higher.
If you are too lean on the oil, the initial effect is that the bike makes more power (less drag from scraping oil off of the cylinder walls, squeezing it out of bearings, etc) up until the point where it runs dry and begins to seize.
And yes, motobecane made 20mph models (which are actually rated for 24mph). If it's really pristine, take a look at the sticker on the top of the airbox. It should have the speed rating on it - 20, 25 or 30.
But the loudness is concerning me. Is it exhaust noise, or mechanical noise from the engine? The motobecane exhaust is very effective (quiet) and the motors are also mechanically quiet. If yours is clattering from the top end, it's time to check compression
  Motobecane Cady - kinda slowTopic by: Beamer W Beamer W 05/17/05 03:58PM
  Re: Motobecane Cady - kinda slowRe: Legendre Legendre 05/17/05 08:35PM
  Re: Motobecane Cady - kinda slowRe: Beamer W Beamer W 05/17/05 08:38PM
  Re: Motobecane Cady - kinda slowRe: Steve4040 Steve4040 05/17/05 09:48PM
  Re: Motobecane Cady - kinda slowRe: Don Ohio Don Ohio 05/19/05 09:26PM
  Re: Motobecane Cady - kinda slowRe: Beamer W Beamer W 05/20/05 11:30AM
  Re: Motobecane Cady - kinda slowRe: Nate Rogers Nate Rogers 05/18/05 12:37AM
  Re: Motobecane Cady - kinda slowRe: Beamer W Beamer W 05/18/05 01:08AM
  Re: Motobecane Cady - kinda slowRe: Legendre Legendre 05/18/05 10:48AM
  Re: Motobecane Cady - kinda slowRe: Mike Scouty McScoutington Mike Scouty McScoutington 05/18/05 11:59AM
  Re: Motobecane Cady - kinda slowRe: Beamer W Beamer W 05/18/05 02:35PM
  Re: Motobecane Cady - kinda slowRe: Beamer W Beamer W 05/18/05 02:42PM
  Re: Motobecane Cady - kinda slowRe: EMoped EMoped 05/19/05 11:05AM
  Re: Motobecane Cady - kinda slowRe: Beamer W Beamer W 05/19/05 01:00PM
  Re: Motobecane Cady - kinda slowRe: Daniel Van Donsel Daniel Van Donsel 05/19/05 11:52AM
  Re: Motobecane Cady - kinda slowRe: Derf Yenrab Derf Yenrab 05/19/05 06:05PM
  Re: Motobecane Cady - kinda slowRe: Legendre Legendre 05/20/05 07:30PM
  Re: Motobecane Cady - kinda slowRe: Beamer W Beamer W 05/20/05 07:36PM
  Re: Motobecane Cady - kinda slowRe: Legendre Legendre 05/20/05 09:05PM
  Re: Motobecane Cady - kinda slowRe: Beamer W Beamer W 05/20/05 09:59PM
