Re: "Starter" Cable?
Don Pflueger /
you can use brake cables, but you may need a piece called a knarp on the end if the original cable has a special end. knarps can be bought from any bicycle shop, some hardware stores, and some auto parts stores. does your cable run to the cylinder head or to an arm on the top of the engine case?
