"Starter" Cable?
Rolly /
The "starter" cable on my 77 Puch Maxi isw frayed and broken (it's the cable for the small lever under the LH brake lever - the one you pull, then peddle, then release to get the bike running).
Is this cable the same as the brake cables? Or is it a specifc cable with a special end piece...
I'm trying to order one from mopedwarehouse, but not sure if I just need anotehr brake cable.
Thanks.
Rolly
