Tomos Targa LX Compression problem
Soo heres the problem..... Today on a long ride im riding and all of a sudden my 96 Tomos LX screeches and cuts out. I start it back up and keep going but it happens again. On the way back it cut out another 2 or 3 times and then just wouldnt start back up.
I think its a compression problem because the pedals are turning backwards too easily it seems but im not too mechanically inclined. Can anyone help me?
Re: Tomos Targa LX Compression problem
Don Pflueger /
sounds like your oil pump quit. you need to look at two things first. check your compression with a guage. you want it to be 120 lbs or higher. next, drop your exhaust pipe and look up into the exhaust port. while looking in the [port, roll the engine over slowly and look at the piston side wall. scratches on the side wall are a good indication of what is wrong.
