Re: help!!! engine flooding
Don Pflueger /
spray carb cleaner in the carb throat. try to start it. if it fires you have a fuel problem. if it does nothing, you have either an electrical or compression problem. pull the plug and check for spark. if you have spark, then you have a compression problem.
