Re: power
Jason Luther /
do the wheels spin freely? perhaps your brakes are dragging or the wheel bearings need to be greased. is the chain at the proper tension (there should be about 3/4 inch of slack). moving on to more complex problems.... have you had a compression test? is the choke sticking or is the airbox clogged? is it a one speed or two speed? maybe you are stuck in first gear.-jason
