plug chop?
Ok well im a little confused. At first my ped was running way to rich with the original air box (fouling my plugs, wet and really black), and running about 25 mph. Then I put a performance filter and plugged the vent tube and put a smaller circumference tube into the choke plunger hole and this puppy pulls me 250 lbs to 30mph stock. It idles a little low but consistent. Also bottom end sucks now. but I keep fouling my plugs. I have to wire brush the plug every day. do I need to bring the jetting down ? The only thing I see as far as numbering on the jet is a 252 stamped onto the jet.
Re: plug chop?
I dunno specifically about your bike but, if it's completely stock every attempt should first be made to get it running using the stock components. The air intake system was engineered to match that carburetor. Once you change air intake components to cure a fuel/air mixture problem, you're on your own.. you are essentially redesigning the carb/intake system.
It sounds like the carb was running rich because of air restriction but there are other possibilities. The original problem could be as simple as a too-high float level in the carb. Too much fuel is too easily sucked into the engine.
You added air and improved air:fuel ratio near wide open throttle (WOT) somewhat. However it's still running rich at part throttle. Some system in the carb still has fuel metering problems..
Main jet size controls maximum fuel delivery at WOT.. It has little or no influence at smaller throttle openings.
I recommend restoring the air intake to stock parts and a thorough carb cleaning and adjustment. This bike should run perfectly in 100% stock condition if everything is clean and tight and properly adjusted. Find and fix the underlying rich fuel delivery problem.
Replacing or modifying major parts in an effort to tune a carburetor is not the way to go, imo..
Re: plug chop?
What kind of oil to gas mixture are you running?
Grey
Live to ride, Ride to work
