jet for carb
on a honda 1983 pa 50 how many turns out should the air fuel mixture screw be turned out
also the idle screw
Re: jet for carb
depends on your needs man, the farther out the screw the higher the idle speed & the closer it is to being closed the lower your idle speed. since my Maxi has trouble idling i've set my idle to one full turn out (counter-clockwise) i've actually had the motor just die on me at stop lights, dangerous and embarrasing but since i've adjusted the idle screw for lower engine RPM there are no more stops
