Re: Brake cables or new brake pads??
Silverfox Sullivan /
it sounds like that the brake shoes are so worn that the operating arm is driving the cam over center.
First see if the cable is not screwed up. Disassemble the cable from the brake and see if the inner is free to slide back and forth in the outer. If not, lube it up with a cable luber device. If it is free, take your brake apart to see what is wrong inside.
