Fixing a 1987 Motomarina Raven
Angie /
I just bought an 87 Motomarina Raven that needs some work. I reattached the coil wire but there are 3 other wires that hook up around the same area of the engine and are shaped like little loops that may tighten down with bolts, but I am not sure where. Also the rear brakes are not working, how can I check to make sure everything is working ok with those?? The engine turns and sounds like it wants to start, so I know it isn't frozen. According to the speedo it has over 7k miles on it but ran a year ago before some dumb kid decided to tear it down to repaint, then changed his mind and forgot how everything goes back together. Any tips or help would be appreciated :) Thanks
