Re: Puch oil mixture
Sean Caron /
40:1 is the way to go; your bike will spit just a little bit of smoke; just enough to re-assure you that you have enough oil mixed in with the gas... plugs will last you a lot longer and you will probably notice some performance increase as well.. i have ridden bikes with some seriously oil thick mixes and they tend to want to bog a lot. plus, its easy to remember: 100 mL of oil per gallon of gas.
