Re: Please help - 85 Tomos Bullet - won't start
Don Pflueger /
try the plug first.
then if that dont work........
spray some carb cleaner into the carb throat. try to start the engine. if it fires, you have a fuel problem. if it does not fire, you have either a spark, or compression problem. remove the plug and test for spark. if no spark, clean and regap the points. if you have spark, check compression. compression needs to be 120 lbs or higher.
