NC50 DRAIN
well my problem is , that i need to drain my oil on my nc50... now there is a hole on the the front of the wind up kick start thingy. on this bolt there is a clip that hold the overflow/drain hose. is this the only hole that will drain oil , and if so any tips on how to drain it.
Re: NC50 DRAIN
Jonas Quimby /
For draining the transmission oil, there's a screw along the bottom edge of the transmission. It looks a bit differant from the others. This is the one to remove to drail your tranny oil.
You then fill it up with the bolt that holds the drain tube. Fill it until it's close to level with the fill opening. About 0.8 of a quart of non synthetic SAE-30.
