Re: brake switches HELP!
Daniel Van Donsel /
I had the same problem... easy fix...
They make 2 types of switches that look identical (round and screw into the Magura setup and the brake lever pushes in the pin)
When I got my ped some freak had put the wrong kind in and then when they didn't work just cut the wires and taped them together so the brakelight was on at all times grrrrr...
I finally figured it out and ordered a set of new correct switches and the brake light works perfectly now!
Chris from mopedwarehouse.com has them... just get the correct kind and screw them in and presto... perfect brake lights!
