THE EASIEST QUESTION
Brian /
I just bought a very clean/nice looking Tomos SP 1986 moped. Here is the easiest question you have had all day:
-How do i start this beast?
I never had a moped when I was a kid, and I can't figure it out quick enough (i want to be riding today!)
Here are my thoughts to help steer you to what i need
-Fuel ON (i see a fuel valve, but they are not marked as to on off- how else can i tell that fuel valve is on)
-Power ON (I found the run button, we are set)
-Peddle Start (I understand that peddle 'kick' start is needed)
-Clutch? Confused here: please help
Is the cluth/brake a combo lever, or should the clutch cable be on the right side?
Thanks in advance- I would like to try to see if I can get it to turn fire first and then troubleshoot any issues later.
