THE EASIEST QUESTION
I just bought a very clean/nice looking Tomos SP 1986 moped. Here is the easiest question you have had all day:
-How do i start this beast?
I never had a moped when I was a kid, and I can't figure it out quick enough (i want to be riding today!)
Here are my thoughts to help steer you to what i need
-Fuel ON (i see a fuel valve, but they are not marked as to on off- how else can i tell that fuel valve is on)
-Power ON (I found the run button, we are set)
-Peddle Start (I understand that peddle 'kick' start is needed)
-Clutch? Confused here: please help
Is the cluth/brake a combo lever, or should the clutch cable be on the right side?
Thanks in advance- I would like to try to see if I can get it to turn fire first and then troubleshoot any issues later.
Re: THE EASIEST QUESTION
Ok, I am one step further.
-I grasp that the pedal creates electricity to drive the ingition coil. However, next I trace the wiring from the on/off switch and see that a few wires are unplugged.
I need a wiring diagram - Anyone know where Tomos diagrams are located?
thanks
Leon Swarmer /
look at Fred's guide uner resources.. then go to
http://www.mopedriders.org/article_cat.php?fldAuto=2
and look for the appropriate Tomos manual
don't know that specific moped,
fuel petcocks usually are 3 position on off reserve.
